What's new
37x13.5 on Stock Wheels
Rho5280
‘25 RHO
There is confirmation all over the TRX forum that 37x13.50 tires fit on the stock wheels with no lift and no rubbing. Fair to assume this should be the case for the RHO as well?
Anyone on here have this set up yet? Tx
It will for from what I hear but for pavement princesses… if you actually it off road you’ll probably rub when flexing the suspension.
Thanks. From what you’ve read it will not rub or you know it will not from experience?
Read but also from a buddy that had a TRX and he leveled the front end 2” to avoid rubbing… but to be fair he didn’t attempt off-road without the leveling kit. I’m guessing he did his research before investing in a leveling kit.
You might be better off hopping on the TRX forums and chat with those guys. But RHO I’m told is identical set up. Same off set wheels/same suspension
Thanks again. Ya, TRX forum is where I am getting my info from as well. Most say it’s fine. A couple have said it rubs but may just be a function of over 37” toyos.
37x12.5 should fit on factory wheels if you're not offroading hard. I'd be careful jumping on 37s.
Not my photos, taken from TRX forums. This is full compression on factory beadlocks and factory 35s.
Edit: I'll also add that Fullthrottlerick on the TRX forums is running 38s with a slight lift and rock crawls all the time.
1" increase in ground clearance isn't worth the effort to me.
