BD s2 lights as ditch lights
FiFdYnUtZ
25 RHO FBM
considering the SDHQ ditch light mounts with baja designs S2 pro lights. does anyone have any pics of this setup on any vehicle? I dont care for the super large ditch lights look and think these might be small enough to look decent and still have useful peripheral light output.
Thanks!
for what its worth, I went with SDHQ brackets and morimoto 2bangers. super bright and the mount fits perfect
Looks great, I am going to visit a shop around here about ditch lights and reverse lights, that’s the look I want for sure
I used Shawn liger at hammer performance to spec everything out. He is great!
I know this is a super old post, but Morimoto lights don’t get mentioned much. Which beam pattern did you go with? I’m looking for something that will extend out far enough to be 80mph “deer lights” basically to widen my bright lights. Looking at the combo high output version with M&R mounts-I like the tight to the hood setup if they would work together. Any advice would be appreciated. Also considering the M&R pro 23” if anybody has input on that for this purpose
I run Baja Designs squadron XL’s and SDHQ hood mounts. They work very well. That probably doesn’t answer your question, but you won’t outrun that light output at 80 mph.
RHO Mud Flaps Dim Low Beams Upgrade Your 2025+ Ram RHO & Ram 1500 This Holiday Season with 15% Off GO Rhino at JustBoltOns.com! First look at Serrano Green Has this happened to anyone else ???? 37s + 18s + Eibach
