Eibach 1.6” level spring
daniellelaven022
AZ
2024 Ram 2500
2025 Ram RHO
Has anyone installed the TRX 1.6” front level spring only on their RHO. If so, feedback would be appreciated! Thank you!
Not to hijack but just checking in - any progress on your truck's issues? Hadn't seen anything in a bit and hoping for the best for you.
No worries! Coolant leak did a little more investigating. My apt for dealer is on the 10th for the coolant leak found seam sealer overspray factory just painted and cleared over 🤦🏻‍♀️ on my drive side rocker panel at rear corner that is getting fixed on Monday at a local body shop. so that’s why I made the apt for the 10th but honestly I think when they did my cats the tech didn’t put my coolant hose on properly which is what’s causing the leak ill attach a picture. My local dealer is going to run thru it all when I drop it next Monday I’ll let you know the update on that
This is replacing the factory springs with taller spring? Guessing this is a better option than adding a spacer block.. spring keep the ride closer to factory softness?
Yesss, my plan was to use it to level a trx I had but never got around to it. So now I would like to put them on the Rho, I am assuming the front end weight of the truck is a little less than the trx. Just wondering if anyone installed and it leveled out nicely. Was going to level it as I’m not a fan of the rake, and put my new wheels and tires on.
Are you going to install them yourself?
My husband and his brother were planning on it or when it’s in the shop for the coolant leak I’ll try and get my buddy there to install them. May throw some money in the box and tell him if he’s not too busy since it’ll be there for a few days.
Just installed the springs yesterday!! Ran into a little issue with my KMC wheels so right now I have my tires installed to the factory wheels which we are working on getting figured out currently! I will say though I’m in love with everything about it!!
How's the ride quality?
so far so good. Haven’t driven it too much. It is a littler firmer as is most leveling kits we’ve had on trucks. Nothing to complain about yet, but will have a better review once I take her out in the desert!!
The Foutz leveling system and ones similar are actually preferred method if you’re actually going to off road. The springs add unwanted pressure to the suspension and have been shown to grenade at fool droop if actually off roading. Check out all the problems raptors have. If you’re using the springs it’s recommended to add limit straps but this is only if you’re actually serious about off roading
Awesome! To clarify, you did the front springs only +1.6? Thinking about pulling the trigger on the +2.7" Front | +1.5" Rear setup.
Never had an issue with these springs on my Raptor or TRX and I’ve taken them both off-roading. I don’t plan on going full Baja mode on my daily driver though either.
That would be a good set up! This 1.6 definitely picked it up more than the 1.6 inches It does on the TRXs. The set up you are thinking about would definitely put it more level. We are hoping this will drop a little it’s about 1/8” higher up front right now.
Looks amazing! I have these in my garage just waiting to go on!
