- May 21, 2024
- 38
- Media
- 1
- 49
- Military
- Army
- 2010 VW Touraeg
- Current Ride #2
- 2015 GMC Sierra 1500
Awesome thanks for the info, I will do this or register it in a different state since I'm military and currently overseas.I literally just had the same issue. I bought the truck in Oregon, came back and it passed the DMV sticker inspection but failed SMOG because of a permanent ABS code. I went round and round with the CA state SMOG referees already, so let me save you some time. I did not have any indication or fault lights either. Basically a permanent code cannot be cleared by the dealer or anyone else. The truck must remove it once it decides the parameters have been met. You need to drive the truck a minimum of 200 miles and have at least 15-20 start cycles on it before you re-smog it. Once you meet those parameters the states SMOG computer is programmed to ignore it even if it hasn't cleared yet. The SMOG stations may not be familiar with this policy so be prepared to tell them to smog it anyway because they will insist the vehicle will fail. I have passed SMOG and just got the truck registered even with the permanent code still present. Just remember a start cycle means the truck fully warms up and cools down, before counting the next cycle.
EVAP is the only readiness monitor allowed to be “not ready” to pass.Failed for a permanent CEL, odd thing is it never illuminated or gave any other problem.
I valid data from brake systems control module
Code UO418
AWESOME GRIMLINS
Well it's on the printout from the inspection station, then I also pulled the same code. So I guess I can put more then 178 miles on the truck, but it's pretty stupid either way for a new truck to fail smog via a codeare you sure it was that code? I've never seen a cali inspection sheet before, but it looks like you had an oxygen sensor not ready
If you bring a vehicle into CA from out of state it must be smogged, along with weight certificate (commercial/ pickups) if it’s not on the title already, and a VIN verificationWhy are you getting a smog check? I thought new vehicles are exempt for two years?
Try driving it to get your Oxygen monitor and Catalyst monitors to run. Those are what more than likely failed you. Good chance the permanent code will clear itself by the time those monitors run too. Let me know if you have any questions, I have a CA smog inspection and repair license.
That was my next answer California haha.If you bring a vehicle into CA from out of state it must be smogged. Along with weight certificate if it’s not on the title already
CA is super gay for out of state cars, so they have additional regs, smog, weight and cin inspection. I really should have made a shell company in Montana then registered it there.Why are you getting a smog check? I thought new vehicles are exempt for two years?
Only if you buy out of state and “bring intoI lived in CA since '06, and have never had to smog a brand-new vehicle...
Well, that's not entirely all together accurate. Can't and shouldn't are differentBasically a permanent code cannot be cleared by the dealer or anyone else.
I've got the same code, but with a CEL on the dash and also code P1CEA so that must be the one causing my light.Failed for a permanent CEL, odd thing is it never illuminated or gave any other problem.
Code UO418
AWESOME GRIMLINS
This seems to be a common permanent DTC for RHOs and it's probably just a glitch. I live in CA and ordered mine from out-of-state. Had the exact same issue. As a couple of others have already said, just put at least 200 miles and 15 warm-up cycles on the truck and the code will be ignored. Your remaining sensors should also be ready by that time. You'll pass as long as the MIL is not illuminated.Failed for a permanent CEL, odd thing is it never illuminated or gave any other problem.
Code UO418
AWESOME GRIMLINS
