I dealer-service changed my engine, front & rear differential, and transfer case lubricants at 5,094-miles. The engine oil and front diff fluid were in good shape. The lab analysts expressed concern over the oxidation byproducts in the transfer case and wear metal content in the rear diff. The fluid change should overcome any potential issues. Excerpts from the lab reports are attached. I do not know whether the transfer case or differential fluids were low at the time of service; the technician forgot to check levels before draining the gear cases.
I usually drive moderately with most miles on state highways and Interstates (60- to 80-mph) with occasional WOTs from stopped or to pass vehicles. Some winter idling on colder days.
Component | Lubricant |
Engine | Pennzoil Ultra Platinum 0W-40 |
Front Axle | Mopar Synthetic 75W-85 |
Rear Axle | Mopar Synthetic 75W-140 |
Transfer Case | Mopar BorgWarner 44-40 |
