Quarts of oil?
yoda33073
2025 RHO
Has anyone done an oil change yet? How many quarts of oil does the RHO take? Conflicting answers out there. Thanks
Excellent info there by @RHOfan
When I drained, I got almost 7.5 quarts out. Refilling, I only put 7 quarts back. I figured a little under-filled is better than overfilled. When I ran the process to update the oil level gage, it showed 1 bar below Max. Per the manual, this is “OK”.
Since 4 bars below max requires adding a quart of oil, 1 bar is likely 1/4 quart below max fill. I’m ok with that. Way better than overfilling.
Owners manual says 7.5 qt
Engine Oil — 3.0L High Output (RHO) Engine - We recommend using Mopar® API Certified SAE 0W-40 Full Synthetic Engine Oil,which meets the requirements of the manufacturer Material Standard MS-A0921.Equivalent full synthetic SAE 0W-40 engine oil can be used but must have the API Donut trademark with a certification level of API-SP or later. API-SN+ is also acceptable.
