- May 22, 2024
- 423
- 599
- BMW X5 M50i
We’ve all seen the abuse the front half of the flared bedsides takes from debris thrown up by the front tires. It’s bad. So, I had the front half of my bed PPF’d. Not the best solution, as there is a visible cut-off line above the wheel. But, it WAS the most cost-effective option ($500 vs. $1500 to do both complete bedsides).
Well, I’ve installed the WeatherTech front mud guards. After 16+ miles of off-road, some at high speed with front wheels spinning around turns, I noticed something. The mud guards protected all but the most bottom portion of the bedside! That lower portion took some heavy hits (enough to tear the film).
What’s great is you can probably get away with just applying PPF to that lower section on both sides & use the body crease line (where the two-tone starts) as the film cut-off point. It will be much less expensive & nearly invisible! Of course, that’s assuming you also install the WeatherTech front mud guards.
I’d also highly, highly recommend doing the headlights & painted spats below the headlights, front radar cover & fog lamps. I don’t tailgate, but both my headlights already have some impact marks on the film.
I’m not the biggest proponent of PPF, but used strategically, it can be cost effective & highly useful.
