- May 22, 2024
- 397
- 551
- BMW X5 M50i
Don’t have enough miles to do my 1st oil change, but plan on getting all the break in material out at 1K miles. Some may argue that is unnecessary/too soon & they are not 100% wrong. Plasma spray cylinder bore liners don’t really “break-in”, but other parts do, especially main bearings. Regardless, I’m creating this post for the DIY folks who will eventually need this information.
After looking under my RHO, I must say that drain bolt & filter access are excellent. Oil changes should be pretty easy without a lift.
For those headed to the dealer, RHO oil changes will cost $120-$200, depending on your market. The manual says go by the electronic monitoring system for change intervals. Odd, as someone posted a different manual a few months back that stated RHO oil changes were to be completed every 4-6K miles, depending on usage. I got a generic 2025 Ram 1500 manual that applies to all sub models, along with a Ram 1500 Consumer Guide & a Quick Start Guide. Not sure what happened to the other manual…
1st…the oil filter part# is not published in my manual, so I’ve attached a photo of the one currently in my truck. It’s a Mopar 68466307AB. MSRP is currently $10.05. All Mopar Parts Online currently sells it for $7.xx, but after $12.xx shipping to my location…hmmm. Amazon has it for $22.xx, no shipping charge. I’ll probably pick up a few next time I visit my dealer. They mark up the retail parts counter sales 25% to cover their “shipping cost” (IOW, added profit), but still the cheapest option for me.
For oil, the manual says to use 0W-40 Full Synthetic, API-SP (SN+ also acceptable), Material Standard (MS) A0921. The only oil I’ve located that STATES it meets both is Pennzoil Ultra Platinum with the SRT logo. There are other less expensive oils that are API-SP, but ChatGPT says the MS is more important for modern engines. So, I’m sticking with the Pennzoil SRT stuff.
It currently retails for $13.49/QT, but Walmart, Amazon & NAPA have it for less than $8/QT. I could not find it in the more economical 5-QT bottle, at least not in 0W-40. You’ll need 7.5 quarts, including filter. Remember to fill your filter before install.
Good luck & post any challenges or lower prices as you either do the work or have it done.
