What's new
AMP power running boards issue with RHO
SeanP
2025 Ram RHO
So I purchased “AMP Research PowerStep Plug-N-Play | Fits 2019 - 2024 RAM 1500 | 76240-01A”.
I installed it today, but ran into on major snafu.
The instructions say to plug the 2-pin into the green block at this location. That’s the problem. I don’t think our trucks have this green block.
Any one know where to get signal that the doors have been opened?
I went ahead and put the fuse in and thankfully they retracted from the install/down position to the up position, so they are out of the way. But, they obviously don’t move when the doors open since they aren’t connected to the 2-pin sensor.
This photo is from an install video I found for a TRX.
This photo is from a similar position in my truck. The green blocks are missing.
So my dealer ran into this issue when he tried to install the 2024 mopar power running board on a 2025 RHO.. he installed it and went to hook it up and found out the wiring harness is completely different on the 2025s.
I had him order me some boards as well with install and they had to order 2025.
These trucks are “ identical “ to TRX until it comes to some of the technology. Same issue with the Tazer DT, they work on rams 2019-2024.. some stuff really can’t be reused from 2024.
