If I'm going to go to the effort of tossing blocks in bed to drop it, I might as well just park it out over night with a ship anchor bolted to it....LMAOI don’t have a link for the shark fin delete, but here’s what I did. I adjusted the upper travel limit on my garage door lot go as high as physically possible. My truck (6’-10 1/2”) now clears the opening by ~1/2”. I even considered putting weight in the bed if it wouldn’t make it, because I refuse to leave my truck out overnight.
So the overall height to the top of the antenna is 6'10.5" or less?I don’t have a link for the shark fin delete, but here’s what I did. I adjusted the upper travel limit on my garage door lot go as high as physically possible. My truck (6’-10 1/2”) now clears the opening by ~1/2”. I even considered putting weight in the bed if it wouldn’t make it, because I refuse to leave my truck out overnight.
That's the question I have asked everyone on here who posts they took delivery on their truck to measure - and I am 0/6 on responses.So the overall height to the top of the antenna is 6'10.5" or less?
He has the ram bar on it so def taller than stockSo the overall height to the top of the antenna is 6'10.5" or less?
Post in thread 'Who still does NOT have a scheduled date?' https://www.ram-rho.com/threads/who-still-does-not-have-a-scheduled-date.319/post-10100T
When I get mine back tonight I will do my best to measure for you.T
Hi there and thank you! I was able to pull mine in to my garage no problem. With the antenna location in the back of the cab, the front lifts onto the garage floor sooner than the back and gives even more clearanceWhen I get mine back tonight I will do my best to measure for you.
Interested as well. Thanks for doing this.When I get mine back tonight I will do my best to measure for you.
What is your garage door height? TxHi there and thank you! I was able to pull mine in to my garage no problem. With the antenna location in the back of the cab, the front lifts onto the garage floor sooner than the back and gives even more clearance
My Sierra 1500 AT4's shark antenna was in the front by the windshield and it had much LESS clearance than this RHO. A level kit and 37's would pose no threats to the height
