Eibach springs
May be an image of text
Local truck and 37's
That truck is 1.7 and 1.5
Those are a good looking wheel but when you go black, they could be any wheel. You can only see a difference when its not moving. Guess im a minority :) I like contrast
No i completely agree, Black wheels disappear easily in photos too. Believe the customer scored those on marketplace and reached out to us for the springs! Looks good though!
I'm even more confused now. Why is the RHO Eibach pro kit +2.7" Front | +1" Rear? And then Eibach lists the others individually (1.6 F, 2.7 F, and 1.5 R) Was there a different package option on the TRX I wonder?
There is a 2.7 and a 1.6(or 1.5) for the front
1.5 for the rear and an HD for the rear.
Eibach has changed the height publications on springs several times on this platform as well as others so I'd take the exact numbers with a grain of salt unfortunately.
if you see here they list several height variances with still using the TRX Spring Part Number
Called Eibach and they believe they have a typo on one of the listings. They are going to research and fix the numbers this week hopefully.
The individual parts and the pro kit don't match up for the rears. So my question was, which rear does the kit come with? I'll keep an eye on the website and update later.
*Update: The pro kit now reads 2.7F/1.5R
Thats because their one it is using the HD spring in there for some odd reason.
I'd like to install the Eibach kit both front and rear, but I need to keep the factory rake. I tow a boat 1-2 times a month and don't want the truck to sag too much when towing it
better pic the reverse rake isnt as present as that photo made it seem
What? Thought you were set on eibach? Tell me about these collars.
I had bought the foutz collars before the RHO eibach springs were released, I’m sure either will work fine. What are you going with?
What’s everyone going with, eibach springs made for the RHO or collars?
This page is great for reviewing as they pretty much all have the 2.7F/1.5R kit and the rake looks perfect. Also, good place to imagine wheel/tire sizes for your builds.
I think either is going to work perfectly.
I’m going the eibach route. The only issue is trying to find the right height.
