Go Rhino Runnig Boards
anyone tried the RB30's? they appear to be about .5" narrowed and have a wider profile at the front
Dont 100% know about the RB30's - @Nick797 may have some insights - the pic on page 2 of this thread is the RB20's and they are tapered front to back - you cant really see it (1 inch taper over the length of the board) I happened to catch it when I was lining up measurements.
Here are the RB20slims. I didn’t want them any wider.
I apologize if this has been covered. Has anyone installed the Go Rhino RB20s? They're quite a bit less than the Mopar set. Need to get a set ordered tomorrow.
Had them on my 2021 TRX, hod no issues with them. They looked great and had good texture to them.
Are these pretty simple to install? Do they just bolt to existing holes?
How do the RB20 or 30's compare to the factory MOPAR ones?
Super easy. My wife n I did ours.
Looks great. Thanks for the quick reply!
I don’t know anything about the factory boards but my RB20s were very easy to install. Just make sure you take a wire brush or a dremel with wire brush attachment to the bolts to remove paint overspray. I couldn’t get the nuts on without doing that from the paint overspray.
I don’t know anything about the factory boards but my RB20s very very easy to install. Just make sure you take a wire brush or a dremel with wire brush attachment to the bolts to remove paint overspray. I couldn’t get the nuts on without doing that from the paint overspray.
I had a couple like that but just powered through them. To me, taking a dremel to em would add too much time 😂
Almost did that but knowing my luck I’d strip them all and end up making a week long project out of it haha
If things can go wrong , they will with me 😂😂
So I do appreciate what you did. :)
