What's new
Go Rhino Sports Bar 2.0 w Power Actuator
Phil Hergutz
Coast Guard
2025 Ram 1500 RHO
I just had an EGR power tonneau cover put on my RHO, and the Go Rhino Sports bar with power actuated lights. I went with 6 of the Dynamic Diode SSR combo white lights with backdrop colors.
To install the sports bar I decided to mount it to the tonneau cover T Slot track, which turned out rather nice. The tonneau cover is amazing and uses the factory Ram key fob to open and close it (hard drum style). The Sports bar sits up about 1.25” higher than it would if not mounted in the T slot. The only problem I have is the power actuated bar is a 3 way switch and they couldn’t figure out how to use the 1 way dash auxiliary switches. I left them unhooked for now until I can figure out a relay or something to use the aux switches to fold the actuator up/down. I just am not sure I want to add a 3 way switch to the clean interior if I can avoid it.
One last thing if anyone is looking for a power tonneau cover I recommend the EGR Power Rolltrac. It can actually work with the Go Rhino sports bar mounted in the c-channel of the sports bar (basically the sports bar mounts to bed rail, the tonneau cover slides in the c track and sits on the bottom mounting plate of the sports bar. But I decided to go with the mount onto the T slot of the tonneau cover. Anyway, it’s a slick looking setup and I am certain I was the guinea pig for this setup on the RHO.
Will post pictures if any Is interested when I get it back from getting the windows tinted.
@Phil Hergutz do you have any pictures of the EGR cover? Did you install or have it done? I'm also in StL and waiting on my RHO.
Thanks
Thanks
I can get you pictures. I had Auto Trim Design in Farmington do it.
Looks great. Are you happy with it? If you don't mind how much was it and what did they charge for the install? PM me if you'd rather not post. Thanks!
