Sure, for longer periods where I am in and out of the truck numerous times.Can't you just leave it buckled behind you?
I’ve done this before but this gets rid of the annoying beeping. Not sure if it will help your situation..Is this even possible to bypass.
There are a lot of instances where I have to move the truck without actually being on a road.
The truck will not engage drive unless my seatbelt is on.
Any help appreciated.
Did this get rid of the chime 'forever' or is it needed to be repeated after each drive cycle? I will definitely be testing it outI’ve done this before but this gets rid of the annoying beeping. Not sure if it will help your situation..
The procedure isn't required after each drive cycle; it disables the chime until you perform it again, at which time the chime will be enabled.Did this get rid of the chime 'forever' or is it needed to be repeated after each drive cycle? I will definitely be testing it out
