- Jan 1, 2025
- 74
- Media
- 33
- 195
- Location
- Auburn Alabama
- 2025 Ram RHO
6 pack of Pennzoil - PN 550040856
7.5 quarts of oil required.
OEM Mopar Oil Filter - PN 68466307AB
Tools needed 13mm socket for oil drain bolt.
Oil filter wrench for 2.92" diameter filter body.
Oil catch basin.
The truck is high enough - no need to jack up. No underbody panels to remove.
Oil drain plug location. (bar with 696AA on it is the Front Anti-Roll Bar) The subframe connector/rock slider that connects the front subframe to the tail stock transmission subframe is kind of in the way. It will be lubricated and corrosion protected after this procedure.
Oil filter is on the passenger side of the oil pan.
Better shot of the oil filter with the flash on. Lots of room to articulate the oil filter wrench.
I made a quick youtube video on how to reset the oil life indicator on the dash.
Oil catch basin.
