RHO Bed/Tonneau Covers
I’m in your boat. I would like transferring the hard tri-fold cover from my Gen II Raptor to the RHO if it can be done.
Just got my RHO Friday. My Backflip F1 tonneau from gen 2 raptor isn't going to fit after all. RHO bed is about 3/8" narrower than raptor and not enough play for the cover to fit in the rails. I was hoping it was slightly larger instead because then you would have the option to shim it to fit. Guess Im in the market for a new cover...
Let me know if we can help with a new tonneau cover!
Here's the forum specific discount code: RAMRHO
This is pretty cool
It’s definitely pricey. And unfortunately, the tonneau cover doesn’t roll up as easy as you would think. You have to raise it and pull the Velcro from the bottom side all the way around to roll it up.
I'm mostly looking to get the bed cover to keep my stuff secure. How secure do you think your cover is? Do they lock to the tailgate?
I went with the peragon and love it. They have a new trifold one I would have went with if it was out when i bought my peragon.
I browsed to the mall parking lot and haven't seen the Peragon yet, saw Rough country and the Bakflip, both looked pretty good and flush. Does the Peragon lock to tailgate? how hard would you think it would be to get into it, is the lock massive?
The one i got has no external visible lock, its a pushrod lock under the cover and the tailgate has to be down to access. Its a metal cover, so they would either have to jump on it or cut it open. I will grab some pics after work today.
MOPAR Hard Cover Update:
The two plastic squeeze clips already snapped off in their "not in use" holders.
I needed an open bed on Saturday morning and found the two nylon straps hanging down with the clips still in their cradles.
Have to drop by my local dealer since RAM did the installation.
I have the Lomax cover and pretty happy with it.
Has anyone tried one of these Peragon covers?
*Edit: did some looking into these, the look cool and I like that when fully open, it doesn't block the rear window, but they have an issue with stuff loaded towards the cab, which is how I always pack our gear when camping, so it wouldn't work for me. Also even though it is a hard top, it has a 50lb limit which seems too low.
I've considered one of these for several years and the same thing always stopped me from buy it. The last thing I want to do while camping is climb under the closed tonneau and unload everything from the bed.
Their support team told me people usually get some sort of extended grab hook to pull those items out but that never sat right with me.
I also though about storing shorter items like coolers and boxes that would still allow the Peragon to collapse. When I've almost talked myself into it the price point is the next thing that holds me back :ROFLMAO:
Side view, back tailgate closed, push bar locking mechanism. Whole cover slides forward and collapses near the cab. Can lock open at 1/3, 2/3 as well.
