- Nov 9, 2023
- 42
- 36
Our trucks still have not been built yet.. BUT, our discounts are a little deeper during the holidays so we made sure to snag some parts for our trucks.
I snagged 2 sets of 18x9 Weld Ledge (reusing stock tires)
Window Visors(I dont smoke but they look good!)
Dominator Steps
Have a Hellwig Bar Set aside for my own truck, 99 percent sure this should bolt right on. ( i hated how loose the rear of the TRX felt without)
Rough Country Bed Covers for both. (these things are inexpensive & the same quality as some of the other brands. )
WELD Off-Road Wheel Ledge Six W107
The Ledge W107 features the same look of the popular Ledge Beadlock wheel, but features a simulated beadlock ring for street use. Its rotary-formed construction results in an enviable combination of increased strength and reduced weight for performance both on and Off-Road Wheel. We finish it...
797performance.com
AVS 2019-2025 RAM 1500 / TRX / RHO Crew Cab Ventvisor Outside Mount Front & Rear Window Deflectors 4pc - Smoke
Motorist have been relying on AVS to keep them cool and dry since the original ventshade took to the road more than 70 years ago. Since then, the design has become more aerodynamic and the materials more modern, but the benefits are the same. You'll be cooler in the heat and keep dry and...
797performance.com
Dominator Steps
Go Rhino Dominator D1 Side Steps 2021-2025 Ram 1500 / TRX / RHO Crew Cab
Heavy-duty all-steel construction Corrosion-resistant textured black powder coat finish Offers exceptional rocker protection Cab-length design Full-width, 5.5" wide stepping surface Dimpled step tread with raised, hexagonal pattern for superior grip Simple, no-drill installation on most...
797performance.com
Hellwig 2021-2024 Ram TRX 7/8in Rear Sway Bar
Features and Benefits Solid, heat treated chromoly, rear sway bar Reduced body roll Increased stiffness for improved handling, comfort and safety Everyday drivability and in heavy, tow/haul conditions Adjustable Rate Sway Bar For your money, the best aftermarket investment you can make! Hellwig...
797performance.com
Rough Country Hard Tri-Fold Flip Up Bed Cover Ram 1500 (19-25)/1500 TRX (21-24) / RHO
5.7 Bed Elevate your Ram's functionality and appearance with Rough Country's fifth-generation Ram 1500 Hard Tri-fold Flip-up Bed Cover. Unlike traditional bed covers that limit access to your truck bed, our innovative Flip-up design grants you complete access to your truck bed, making it easier...
797performance.com
