Will there be any performance mods?
Pilot
curious to see how many performance mods will be avaible for the RHO!
Probably none
Absolutely!! I'll be working on some the day I get my truck.
Im sure once there is more support for this engine yes, as far as intake that factory one looks really nice!!!!
Burgertuning/JB4 Beta for the 3.0TT in the Jeep Wagoneer says ~100hp gain, which would be incredible.
Nothing will replace V8 sound, but everything else about the 3.0TT is fine with me.
Says it can be removed without a trace... We will see about that.
100hp gain to the wheels
Can't just remove it, you also have to clear it but yeah no trace. I stopped trading extra hp for reliability and longevity but JB4 is pretty solid
I’m curious to see the potential of this engine. Coming from a built engine hellcat, I’m itching to mod the RHO. I’m hoping it’ll be as stout as the B58.
It will. There's already a piggy back that adds upwards of 100hp. Similar to the B58 piggyback systems.
From what I saw, those results were on the standard output hurricane. Good thing is that it seems to keep your warranty but would 100hp be realistic from the high output engine with the piggy back? I’ll be happy with a stage 2.
I won't be doing any piggy back systems on my RHO, just the basic stuff, downpipes, larger exhaust, cold/hot pipes and larger intake. I'll wait for someone to break the ECM and get a proper tune.
On the JB4/Burgertuning website tuning results were from a high output Hurricane in a Wagoneer I believe? 100hp from just a tune makes sense with the high output engine as it has significant hardware improvements over the low output engine. Doubtful the low output Hurricane will see the same gains with just a tune…
The engine has potential with a good tune, maybe slightly bigger turbos for some more steam up top. I wonder how the transmission will hold up to an increase of hp. Not sure why they didn’t just throw in the 8hp95
Agreed. 553 ft lbs. doesn’t leave a whole Lot of headroom
That engine is easily just as stout as the 2JZ so I don’t see any issues with a big boost in power.
I wouldn't go that far. It's an aluminum block with Plasma Transfer Wire Arc (PTWA) sprayed cylinder coating. The 2jz was an iron block.
Yeah, I wouldn’t put the hurricane in the same tier as a 2jz. But I think if the hurricane gets sleeved and forged internals, it should be able to hit 700-800 rwhp reliably.
It has forged internals
