According to other YT channels the vast majority of RHOs are having problems...lets put a Poll to this
Have you had any problems with your RHO?
  • YES
    Votes: 20 21.1%
  • NO
    Votes: 75 78.9%
  • Total voters
    95
Ugh. Running at close to 1 in 6 trucks with issues - at least on this forum. Hoping that 2,000 people with problem free trucks are out there - and since they are happy as pigs in shit, they haven't visited this forum to weigh in! Only 65 in the survey - hopefully at 10 trucks that have had issue are here!
I’m willing to bet everyone is having issues, one thing or many. I’m willing to also bet RAM knows about all these issues causing widespread issues.
I'm not sure my only issue was one of the fender flare was scratched (very minor one scratch) most likely due to delivery. Dealer ordered me both rears so I just have it as back up not even installed. I also went with same breaking procedure ram recommend at 300 miles and did try out launch control at 1100 miles. Still no issues at 1812 miles but driving it very lightly. Will do oil change around 3k and will be pushing it a lot more.
Received my truck in early January. The day after receiving it, the CEL turned on. The truck would struggle to turn on and also felt sluggish. Truck was giving out codes p0301 302 303 and also p00c6. Dealer determined the high pressure fuel pump needed to be replaced. Three weeks later i got the truck back and it ran good for two days and then the CEL turned back on with what felt like the same issue. This time the CEL turned on right after the auto stop/start had triggered. Took it in and dealer determined the high pressure fuel pump needed to be replaced. Apparently there’s two hp fuel pumps which i think are also called fuel injectors (one for each set of cylinders). I don’t know why they did not replace both the first time since the codes were showing misfires on both sets of cylinders. So now both fuel pumps have been replaced and I’m supposed to get the truck back tomorrow. Oh and not to mention the passenger screen does not work. The screen had power but i could not see anything. Tried the obvious like making sure the brightness was up, sitting on the passenger seat etc. the dealer opened up a case for that and the engineer suggested replacing the security gate way part, so I’m waiting for that also. Batteries were also replaced already.
I’m in California so I still haven’t had the chance to get a smog check to register the truck and the temp tags have already expired. Hopefully everything works out this time around and it wasn’t just a bad sensor or fuse all along.
My climate control system has been dead in the water since taking delivery, the blower motor wouldn’t even turn on. Glad to report that the dealer ran down some bad electrical connections (bent pins, etc) up under the dash and everything seems to be functioning correctly for the first time. Seems like I’m part of the shitty electrical gremlins club just like a lot of others, but at least I now have heat and AC.
600 miles, nothing yet. Other than when I picked it up. Divers door unlock button works but doesn’t pop up. Part on order. No biggie.
400 miles, just software glitches here and there, but have all gone away with the next restart. I love it more with every mile
We travel a lot in business and every dealer service says they are not seeing a lot of problems with the hurricane engine.
Off topic but I also have a Titan and an RHO on order. 💪
Staying off topic, I'm a bit uneasy about this change. 65k miles and 4 1/2 years on my Titan and literally not a thing has gone wrong - I haven't even had to change the battery. I think I'll keep my Titan for a few months to make sure the bugs are worked out on the RHO. Worst case, I'm getting enough of a deal (Koons) on the RHO that I should be able to sell it for about what I'm paying for it. Then I'll just go back to the Titan . . . FWIW, my wife used to have a Nissan Armada. Same thing - 100k+ miles and 7 years. I put a battery in it and new set of tires around 60k. She has a Wagoneer now. It only stranded her once (thermostat), but it does have some electrical "oddities".
My Titan has not been as trouble free, but it’s mostly my fault. A couple small accidents, the lift, etc. I do enjoy the truck tho. I am hoping that the RHO is a world ahead in terms of ride quality, refinement etc.
I ordered through Koons as well. What stage is your order in?
Yeah - my Titan is reliable, but crude as hell. I have the XD version too - so supposed to have the tires at 65psi. I run them at 50psi to smooth things out a bit - but still rides like a brick!
I'm at KZLD - which is basically an "unpublished" status. The LD stands for "long delay" - which means waiting to ship for god knows what reason. There are 6 or 7 Koons orders right now at that status - so can't imagine that logistics are the issue with 6 or 7 ready to all go to the same place. And that's just the ones at LD status! My guess is they are all broken/having issues - I downloaded the app almost two weeks ago and it appears that my truck has not been started or moved - perhaps ever. I used to have an April 24 estimated delivery date, that was changed to late March a few weeks ago and now it's TBD. I have a 1/7 order date and 2/22 built date. Roll the circus music . . .
#RHOlife
I'm at KZLD - which is basically an "unpublished" status. The LD stands for "long delay" - which means waiting to ship for god knows what reason. There are 6 or 7 Koons orders right now at that status - so can't imagine that logistics are the issue with 6 or 7 ready to all go to the same place. And that's just the ones at LD status! My guess is their are all broken/having issues - I downloaded the app almost two weeks ago and it appears that my truck has not been started or moved - perhaps ever. I used to have an April 24 estimated delivery date, that was changed to late March a few weeks ago and now it's TBD. I have a 1/7 order date and 2/22 built date. Roll the circus music . . .
#RHOlife
I ordered 2-17 and I’m currently scheduled. I’m starting to think none of that really matters tho.
Good luck…. I’m sure the truck will be worth it! Maybe I’ll even bump into you at Koons!
Brand new RHO owner Bed Step Recommendations Misfire issues reported - 2025 RAM 1500 Back to the Ram RHO Delivered What did you do to your RHO Today?
