Did anyone ever figure this out (if we need to trickle charge both batteries or just the main)? I bought one of the NOCO dual bank (2A per bank) because I am going away for a week at the end of the month and really don't want to risk getting back to a dead truck.I'd like to know about that as well, do we need to hook up both to the charger or just primary?
What would be a better solution, if someone wants to figure out how to do the true dual full size battery's like the diesel 2500's/3500's have with voltage isolation option.. one can dream right
What are the specs on the Auxiliary battery?
Thank you!![]()
Duralast Platinum AGM Battery BCI Group Size 400 200 CCA AUX14
Shop for Duralast Platinum AGM Battery BCI Group Size 400 200 CCA AUX14 with confidence at AutoZone.com. Parts are just part of what we do. Get yours online today and pick up in store.www.autozone.com
That's true and a great point. Watching @Ctech-Review battery replacement video, you can clearly see the negative terminal from main also jumps over to auxiliary battery's negative post. In other words, you don't need a dual bank charger for these, only a single is sufficient.For what it is worth, I checked out a few different jeep forums and it sounds like, vehicles with the main and aux battery, are wired in parallel. So we don't need to trickle charge both batteries, just the main - which will feed the aux battery (assuming both batteries are functioning properly).
I am not an expert (but I did stay at a holiday inn express last night), but it will depend on your use case. If you are using it as a battery tender or trickle charger, I'd think you want to stay below 2A. If you are planning to use it as more of a battery jumper you would likely want 10A+.That's true and a great point. Watching @Ctech-Review battery replacement video, you can clearly see the negative terminal from main also jumps over to auxiliary battery's negative post. In other words, you don't need a dual bank charger for these, only a single is sufficient.
HOWEVER, I did notice the auxiliary battery's Amp Hour is rated at 14Ah, meaning watch the amp rating on the charger you put on it. Can we run a charger that's rated at 10 amps or even 20 amps to it safely? Or...should we stay within 5 amps only?
I agree but I am way to big of a puss-puss to try this out on mine haha. I have been problem-free since my first night when the batteries died (aside from getting a tear in my front driver CV boot) and I don't want to rock the ship here.this can all be a moot point if we can get rid of the aux and use an h8! I would really like to try it by just removing the fuse, then covering the positive and negative aux connectors and see if the h7 will work. Just no time to do it. my fear is the aux battery sensor not seeing any current will make the truck throw codes.
haha exact same hereI agree but I am way to big of a puss-puss to try this out on mine haha. I have been problem-free since my first night when the batteries died (aside from getting a tear in my front driver CV boot) and I don't want to rock the ship here.
Jump start instructions are on pp. 292-293 (PDF 294-295) of the Owner's Manual or the attached doc.We need to figure out the proper way to jump one of these trucks in case battery dies, for some of us being stranded is not an option. Need a fall back option in case one or both die.
Like someone posted before you can remove the aux from the equation if it fails. We do something similar on the wrangler JL’s with the aux battery. Even with a jump when the aux fails the Jeep will not run.We need to figure out the proper way to jump one of these trucks in case battery dies, for some of us being stranded is not an option. Need a fall back option in case one or both die.
