Battery Dead
Still not 100% sure it's a fix, but:
1.) remove key card from truck, mine was still in the truck when it died.
2.) I deleted the app from my phone, not sure if this really did anything or if it was the key card in the truck. I may try downloading the app again to see if it is really an issue or not.
3.) After batteries were dead, I replaced both with new duralast platinum agm(AutoZone).
So far, all has been well. I'm up to 1,200 miles and the truck just sat for 2 days and started right up this morning.
Can you share the exact batteries you purchased? I didn't realize there was a second, smaller battery. I'm also dealing with a dead battery issue and am contemplating just changing them myself to avoid taking it to the dealership. Don't know what caused my battery to die... key card was never left in the truck and I don't have the Ram app.
this was the big one, the smaller one was the same manu/type, but I don't remember the size. I brought both batteries into the store and they gave me the sizes. The smaller battery was not on display, they had it in the back.
Why did you purchase batteries from AutoZone? Shouldn’t this be a warranty item? Did you purchase with the intent to get reimbursed?
I was going to have to wait a week or two for a dealership to take the truck, then for all I know, they would just give it back and say there's no problem or have to order batteries. I went to a Ram dealership near my office to see what their price was for batteries, the parts manager said he couldn't even order them in his system. I paid a few hundred bucks, changed them out myself and it was done. the way I see it, I saved myself a lot of time an aggravation, but spent a couple hundred bucks; was worth it to me.
I am inclined to do the same. Was accessing/replacing the second battery straight forward? I haven't taken a good look around to see exactly where it is.
Sounds like what I would end up doing if I knew this was going to be a headache. Luckily the only dealership with a good service department is the GM/RAM dealership here. The Ford and Chevy would put air in your tire, charge you a couple hundred and say that's why your batteries are dead
  • Like
Reactions: out
yup, 10mm socket and need a long extension for the tie down, super simple though.
I guess keep the old batteries to throw back in in case it doesn't fix it and you have to take it in anyway.
this was the other battery, FYI you need an e-torx socket to remove the studs from the stock battery and transfer to the new battery
Thanks for the info. Was able to jump start the truck today. Oddly, the digital cluster showed ~13 V for the current battery immediately after jump starting. I expected to see a little lower voltage in a dead battery (and it was truly dead because I had absolutely no power to the vehicle prior to the jump start). I never got any battery charge warning indicator prior to the battery dying either. Ultimately I said screw it and just drove it to the dealer. They won't get to my truck until next week but I had other issues that I wanted them to look at as well. Maybe I'll regret taking it in, maybe not. Perhaps it will just be a simple battery replacement that solves the problem.
If you turned the truck off, then turned the ignition right back on without startup you'd probably get a battery idea of the battery voltage. That's exactly where I was at, running id be around 13.2v, once I put in new batteries I'm at 14.4-.5v 99% of the time
I dislike the idea of putting another $400 into batteries on a brand new, fully warranted $80+K truck, but I’m at the point now…if this solves my safety system faults, its worth it!
I’m doing my 2nd full battery recondition/charge this week. Batteries won’t stay lit. I’ve also removed the PPF from my radar cover. Giving it one more chance before I go the AGM battery route.
the stock batteries are agm. I agree with you, I dislike the idea, but instead of putting it on a battery tender every night and all the warning lights for the past two weeks, I just paid the 400. If nothing else works, hopefully the new batteries will.
So is anyone using the app? About to pick my truck up and I’d like to download the app but don’t want to risk killing my battery.
I’ve done 3 battery conditions & full charge sessions on mine. I’ve had it less than 3 weeks, yet every time I hook up the charger, it takes a full 36-48 hours to reach float.
Something is killing these batteries.
Wonder if the truck is trying to do a software update, downloading, fails, then keeps trying while the truck is turned off?
I have used the app since I picked up the truck and no battery issues.
I remember when chev. Colorado batteries were dead left and right a year or 2 ago ended up being that where it wanted to do update then freeze and kill batteries
Does Ram give you free wifi for a few months? Or are you suppose to attach to your own Wifi for updates? anyone know?
ive been using the app - left the NFC card in the house (not in the truck) and not had any battery issues .... I have wifi enabled for truck to connect to home wifi when in garage .... as far as Ram / FCA Wifi (mobile hotspot) .... I did not see any free offering, or trial activations - from everything I can tell you activate and pay month to month (or there is a slightly discounted price if you buy a full year) ... also note its 4G/LTE connectivity.
The other connected services have "trial" offers which last anywhere from 3 to 5 years
I deleted the app & none of my issues went away, so I’ve since reinstalled it and no new issues. Turns out my issues (safety system faults) are software related & Ram has no fix at this time.
I have had my truck since December 16 and have been using the app since day 1, No battery issues at all. We have had sub zero temps here for the last couple of weeks with the truck parked outside and only used a couple of times a week. Starts righ up everytime.
Aftermarket spray in bedliner Some photos from Prairie City today Baja Design LP9 Bump kit 💰 Tax Refund Sale – Get Up to $800 Back on RealTruck Accessories for Your Ram 1500 RHO! May-April-June orders… who still isn’t scheduled? Testing the DiabloSport CAT 6 with Draggy
