Page 125 of the Owner's Manual shows:Could someone please help me out with the first break in service for RHO? I’ve seen a bunch of different answers online, but I can’t seem to find the right one for RHO. Thanks a bunch!
Agreed. I follow BMW break in rules, they've mastered it. Per your guidance above, it follows very similarly to BMW. I'll be changing the oil/filter and rear diff at 1200 miles. I mean why not...I've waited this long for the truck I can endure a proper break in period, I ordered May 14th, still in D status...which is so fucked up, but I can't control it.Page 125 of the Owner's Manual shows:
Edit: I initially misread your post when I added the engine break-in recommendations.
As you mention, there's a lot of different answers/thoughts out there. The Owner's Manual doesn't give special guidance for a first service beyond 4,000- or 6,000-mile intervals, based on duty.
Here' my two cents: I typically change the engine oil and filter at 500-miles. Then the engine oil, filter, axle & transfer case lubricants at 5,000-miles, and follow the OEM maintenance plan to the nearest 5,000-mile intervals afterward.
Hard launches from stop I definitely wouldn’t do, I’m not. However, it is advisable to accelerate from 60-100mph, you just want to avoid high rpm. It’s harder on a motor when you launch from a stop. I have always aligned with more of the BMW break in process and it has always worked well considering numerous compression tests I’ve done with each vehicle. I’ve had BMW M series (still own M3), Cadillac V’s, Ranger Rovers, Porsche, Vettes, etc. All had very high compression so I fully believe in a proper break in.So, drive only stop-and-go, grocery getting until you hit 500 (or 1,000) miles, then change Oil, Oil Filter and Diff? Should any JiffyLube type shop be trusted to do this?
When is it safe to tow my 6K lbs, 24' boat?Hard launches from stop I definitely wouldn’t do, I’m not. However, it is advisable to accelerate from 60-100mph, you just want to avoid high rpm. It’s harder on a motor when you launch from a stop. I have always aligned with more of the BMW break in process and it has always worked well considering numerous compression tests I’ve done with each vehicle. I’ve had BMW M series (still own M3), Cadillac V’s, Ranger Rovers, Porsche, Vettes, etc. All had very high compression so I fully believe in a proper break in.
Man this will get a lot of negative opinions, I’m sure, but if it were me, I’d just wait it out a bit longer till 1000-1200 miles with fresh oil and filter and rear diff fluid change. That’s just me though.When is it safe to tow my 6K lbs, 24' boat?
Sounds fine to me, I just want to be careful.Man this will get a lot of negative opinions, I’m sure, but if it were me, I’d just wait it out a bit longer till 1000-1200 miles with fresh oil and filter and rear diff fluid change. That’s just me though.
KM? How about freedom units?That sounds like a great plan! From what I gather, the key is to drive gently (no sudden acceleration) and avoid high revs in the first 500 km (or maybe 1000 km?). Once it reaches 500 or 1000 km, it’s time to change the oil, oil filter, and transfer case lub?
Thanks for the info! Could you elaborate why it is advisable to accelerate from 60-100?Hard launches from stop I definitely wouldn’t do, I’m not. However, it is advisable to accelerate from 60-100mph, you just want to avoid high rpm. It’s harder on a motor when you launch from a stop. I have always aligned with more of the BMW break in process and it has always worked well considering numerous compression tests I’ve done with each vehicle. I’ve had BMW M series (still own M3), Cadillac V’s, Ranger Rovers, Porsche, Vettes, etc. All had very high compression so I fully believe in a proper break in.
Honestly, I believe it allows the rings to seat properly and it’s less harsh on the motor than you launching from stop. Launching from stop full acceleration can destroy your motor, I’ve seen it happen before.Thanks for the info! Could you elaborate why it is advisable to accelerate from 60-100?
So you are saying don’t hard launch it but do it 60-100 instead?Honestly, I believe it allows the rings to seat properly and it’s less harsh on the motor than you launching from stop. Launching from stop full acceleration can destroy your motor, I’ve seen it happen before.
Within the first 500-1k miles, yesSo you are saying don’t hard launch it but do it 60-100 instead?
ok wow, that's interesting.Within the first 500-1k miles, yes
