- Jul 2, 2024
- 129
- Media
- 53
- 229
- 2025 Ram RHO - Level 1
- Current Ride #2
- 2022 Ram 3500 Limited
Do they even make a cartridge type fuse tap? Being the cartridge fuse is rated at 50 amps I wonder if the trailer camera can supply that much amperage for whatever else is on the circuit. I wonder if F32 is also providing power for the marker lights of the trailer plug. Quick question, Did you test to see if the F32 does energize when the headlight switch is activated or is energized with the ignition. If it is energized by the ignition the BCM may control the marker lights.
