The Great Running Board Dilemma
Anyone interested in selling the original off road running boards?
I found an almost new pair on offer up for $400. Came off a TRX. From what I read, it should fit and look identical to the RHO ones. Probably easier finding ones taken off a TRX than RHO right now.
Small updates
Dominators - Alot of boards were apparently made incorrectly, working with Go-Rhino/Real Truck On resolutions for 2 customers
RB20 Standards - Brackets are currently very very scarce, boards are plentiful, Alot of the open orders right now I'm holding the boards them selves back to not cause confusion.
Small updates
Ok so my RB20 standards I ordered yesterday will be on hold for awhile, got it! Just hope it doesn't take almost 9 months like my RHO... 😂
Ok so my RB20 standards I ordered yesterday I will be on hold for awhile, got it! Just hope it doesn't take almost 9 months like my RHO... 😂
I should probably get a set of RB20s on order for my self at this rate i should have my truck by 2026 since I just went into scheduled after 9 months..lmao.
But no you guys shouldn't be too far out, i figure 2 weeks MAX. I'm stealing brackets from all different distributors we use to try and make it work for everyone.
I took the Go Rhino RB 20 running boards off my 22 Ram and had them coated with bedliner when I had the RHO bedliner sprayed. I love the way they look and function. Highly recommend.
Currently the only ones that work with the head unit and plug up directly to the harness are the MOPAR steps. The others require magnets/door switches to be installed so those you can't leave down if you want. The MOPAR cost more but it's not like those buying a RHO can't swing a few extra bucks if they want them.
MD is doing them for $2500. I thought about installing them myself and saving some money but from what i gather even if I installed them they still have to program the truck to acknowledge them.
Is there a model number for these side steps I just got my RHO and need a set
To correct your statement, the ones with the magnet, at least the Go Rhino E1, has a mounted override switch so that you can leave the steps down when door is closed.
Westin Electric boards will work as well, we have plenty in stock and can discount.
I have the Westin Pro E boards on mine. Very happy.
I did the same with my old MOPAR running boards. Had them on 19 Rebel and line X’d them to freshen them up. They came out great.
I found a set of TRX OEM running boards for sale in my area. I tried searching around but couldn't find a definitive answer. Will they fit on the RHO without modification?
@Nick797
@Nick797
Yep! Same cab physically in that aspect. So wouldn't be an issue at all
Yep, that’s what I did. Found a brand new pair of TRX Mopar/OEM running board take-offs for $400. Fit perfect.
I got the Mopar running boards when I ordered my RHO. They are great in my opinion. My wife can easily get up in the truck and they have plenty of grip.
I went with the GoRhino RB30 with the bedliner material on them. Easy install and should help a lot with the door ding queens.
I love the bedliner option.
